shim removal
ColtIce
Disabled
9 months 43202 summer months 98951
i've seen alot of people who are concerned with doing damage when doing this.there is a simple ,safe way to get it off.dental floss.I used a piece about 2 foot long,started at one corner and in a slow sawing motion worked it across untill it just popped off.a much lower risk than if you used a razor blade or screwdriver.
Ooooh nice tip!
I used a razor and scratched the pcb, but no noticable damage was done when I booted up!
This would work even better if you heated it up w/ a hairdryer before hand. As it (the glue) seems to get more tacky then.
