- Jun 25, 2003
- Southampton, UK
This happened a while ago, but I'm lazy, so I haven't really bothered to sort it out yet, but it's really starting to annoy me now, so here goes:
Norton AV pops up and tells me it's found a virus or something and that it's automatically deleted a file. As it was a while ago I can't remember exactly what it said, but it looked like a windows system file or something. Ever since then (so I'm guessing the deleted file had something to do with this) I get the following message whenever I open internet explorer, or try to install some new software:
"The Application or DLL C:\WINDOWS\SYSTEM32\ShimEng.dll is not a valid windows image. Please check this against your installation diskette"
Explorer then opens normally and works fine. As for when I'm installing software, sometimes it installs and works normally, sometimes it won't install at all (errors again and installer quits), and sometimes installs and then works with errors.
Do I need to use the recovery console to fix this? Any help at all would be appreciated.
TIA,
Blackfist (Matt)
TIA,
Blackfist (Matt)
