- Mar 18, 2002
- The Parabolic Quantum Well
I am putting a new P4 system together soon. Have all the parts already and am waiting, if I could wait, for Intel's planned price cuts before buying the last part, the CPU. I currently have an Enermax 431W PSU and was wondering if this is enough for my use.
Here are what I am going to put together:
Abit TH7II-RAID
Intel P4 NW 2A or 2.2GHz CPU
2x 256MB PC800 Samsung Original 16-device RDRAM
nVidia geForce4 Ti4600 (Will be overclocked)
Creative Labs Sound Blaster Live!
Generic Network Card
2x Maxtor D740X (Quiet Drive) 60GB HDs in RAID 0
2x Maxtor 40.9GB HDs in RAID 1
Toshiba SD-M1402 12x/32x DVD-ROM
HP 9100i (or Liteon 32x burner if I have any $$$ left over) 8x/4x/32x CD-RW
Iomega 250MB Zip Drive
Standard Floppy Drive
Digital Doctor 5 to monitor Temps
2x KWI Removable HD Trays
3x Sunon 120mm X 25mm Fans
1x Sunon 120mm X 38mm Fan
1x Sunon 92mm X 25mm Fan
1x Sunon 80mm X 25mm Fan
The system will be water cooled and the radiator will be using the 120mm X 38mm Fan and I hope on clocking my system to atleast 133MHz FSB with my RDRAM setting to 400MHz so I'm hoping on 2.660GHz with the 2A GHz model or if I go with the 2.2GHz I am hoping on 2.926GHz. This means I'll most likely be using 1.85V for my Vcore.
So is my Enermax 431W PSU good enough or should I get one of those Enermax 550W or other 500W+ PSU. If you don't suggest an Enermax and suggest I invest in a larger PSU, which one would you recommend?
BTW I am currently running my PSU in an AMD system with an Epox 8K7A+ motherboard and am experiencing a low reading on my +5V line. I don't want to go into the PSU and mess around the line like I saw in a mod out there. Would this problem carry over to my Intel system? Thanks.
Abit TH7II-RAID
