- Nov 28, 2005
I got a power failure, so i decided to re-plug every components.
it then asked for a CPU config which i have set back to default before i overclock back. Then cpu-z tells my core speed is 1197Mhz..
wth!?
i restarted pc..
Load everything to defaults in BIOS. then i had a blue screen just right after windows started.
i restarted pc..
Then i tried to PROPERLY reset them again to default. then i get my BIOS hang.. (screen wouldn't change as keyboard pressed, instead it shows dot-dot thingy).
i restarted pc..
monitor stands by, keyboard and mouse dead..
then i turned it off and try to chill down the CPU..
now i got everything's back to normal
CPU temp at 37C, MB temp at 43C. both at idle.
but i feel dead.. should i overclock back to 3.0Ghz ??
wth!?
i restarted pc..
i restarted pc..
i restarted pc..
