Should I put optional fans on my new Antec 1200?
baris_
Hello,
I just ordered the Antec 1200 case and there are some optional fans. Should I buy some and put them on? Is it worth it? If yes, which ones?
Rich'[ard]
Melb, AUS
the Antec 1200 is already awesome for cooling.
it comes bundled with quite a few fans already.
if you don't like the blue-LED fans, want something quieter (eg. Scythe Slipstreams, Noctua fans), want a different colour (Xigmatek orange fans), by all means, change them :thup:
B
baris_
No no, that wasn't what I was getting at. Yes, it comes with 6 fans. Good fans, that I like. But there are 2 more optional fans able to be installed. I think a rear and a side one. Not sure anyways. But is it worth it to get those? Then it has 8 fans instead of 6.
Lavacon
Lost in NH
That case has 3x120mm front intake, 2x120mm exhaust, and a 200mm top fan. You should run it for a bit and see how the temps are. I imagine you are good to go :)
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Heatware Profile
61687
I didnt install the side fan (only one it doesnt come with) on mine. It was fine without. But if you want to, go for it. Why are we making this decision???
B
baris_
It's not like money grows on a tree over here. I was just asking if it is necessary get that extra optional fan on it. If it really improves a lot I would put down money for it.
It is not something I hope for. And even if I did, I still wouldn't know what fan to get.
EarthDog
Buckeyes!
Heatware Profile
61687
Money doesnt grow on trees in the US either. ;)
Just see what your temps are like without. If you WANT to add another one and can AFFORD it, go for it. It cant hurt. Stock though that thing moves some air so I wouldnt worry about it. Especially if money is a concern.
B
baris_
Thank you sir, thanks for the input :) I'll do that.
petteyg359
Likes Popcorn
Heatware Profile
37658
It comes with three 120mm front fans, two 120mm rear fans, and the top fan. The optional fans are side and "duct".
I'm not at home and haven't opened my 1200 for over two months, so don't remember the setup exactly, but there's a bracket for a "duct" fan that attached to the back of one of the drive bays. So, it doesn't come with two fans, rather than one :) You can see it in the fifth image here
11-129-043-S05
EarthDog
Buckeyes!
Heatware Profile
61687
I owned one yeah... forgot about that. The first thing I did was remove that thing though. Again, didnt use it and had GREAT temps.
B
baris_
Do you reckon that should always be removed? I will not use it. Now that makes me wonder, what should I do when I get the case? Anything you lads think I should do before I do anything? Like for instance, removing that fan inside that I will not use anyway?
Btw: Thank you all for your replies. You've helped me a lot!
EarthDog
Buckeyes!
Heatware Profile
61687
Again, its just preference. There is nothing I can think of that NEEDS to be done to it. I just did b/c and for no other reason.
dgb303
5280, USA
I wouldn't worry about the side fan unless you're running a sli or crossfire config where you need to jam extra air between the two cards. Otherwise the case already has outstanding cooling and doen't need any additional fans imo.
B
baris_
Thank you, I will keep the standard setup then. :)
Rich'[ard]
Melb, AUS
oops, soz man, misunderstood.
the side fan is good for cooling down your graphics card/s.
the other rear fan will give you better airflow no doubt. but if you're not a fan of dust or anything...and you don't need taht much cooling, don't bother with it.
B
baris_
Don't worry about it. I do not like dust, especially since I don't have the tools here to remove dust efficiently. I will stay with the standard 6 fans.
