- Dec 17, 2002
- Vancouver, BC
I'm running my NF7-S and 2500+ rig at 11*211 at 1.8V, 2.8V, 1.7V respectively. Ram timing is 11-2-2-2. The rig is housed in a CoolerMaster 200 case, with 2 L1A fans for front intake, 1 L1A for side intake, 1 L1A for top exhaust, Antecc TP 430W PS, and 1 39 cfm fan hooked up to Antec's fan control connector.
Room temp is ~20C (probably lower). Running F@h using the gromacs core my temp went up to 48C today. When I touched the HS it wasn't that warm. I'm using the latest BIOS (20) which I think recalibrated the temp already.
Think I should remount the HS and see if temp will go down? Or does that sound like a reasonable temp?
My 2100+ @ 12.5*170 @ 1.75V is usually around low 40's at full load.
