Should I swap graphics cards or just buy a new one and have 2 computers?
technoViking
San Jose, CA
Hello everyone.
I was wondering what I should do.
I'll probably build a new system by the end of Q4 of 2008.
Well my current system in my sig runs all the new games awesome, the reason I upgraded the graphics card (which I'm glad I did) was because my old one the 6800gt burnt up.
So when I build my new system should I just swap the 8800gt out of this system and put it in the new one or should I just buy another graphics card for the new system, and keep this system around as well?
I know it won't sell for much, so im not even going to try to sell it.
attack
hmmm will your motherboard support C2D's? IF so I'd just upgrade to a E4500 OC it a little and then wait. You won't gain much at all in terms of gaming performance by overhauling everything, and having a second rig is useless for me, especialy one with a high end GPU worth more than the rest of the PC.
technoViking
technoViking
San Jose, CA
hm...my system is pushing 4 years old.
I wonder if it will.
I have an ABIT-AA8XE mobo
Do you know where I can find out if it does infact CD2? That would be sweet if I could just buy a new CPU and jack it in this bad boy
EFF it looks like it only supports P4's.
http://www.neoseeker.com/Articles/Hardware/Reviews/abitaa8xe/
wait a tick, it says:
LGA775 processors
and I googled that and it mentioned Dual Cores. so does that mean I'm in luck?
Mekks
Colorado
it all depends what cards are out when you build a new system imo. unless you plain on playing games on both systems i would swap the GT to your new system, and buy a so-so card for the older system.
jivetrky
Lake Village, IN 46349
I'd agree. Unless there is someone else in the house that might play games (like me, i have a daughter that probably plays more often that I even do) I'd say just swap.
Also, about the C2D upgrade. You could check the manufacturer website and see if there is a BIOS update available. If there is, download it and check the change log. See if it shows mentions of C2D CPUs
djrussell
everett, wa
board specs: http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=2&model=236
bios updates: http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=3&model=236
it looks like although it is a socket 775 board, it doesn't support c2ds. i could be wrong.
technoViking
technoViking
San Jose, CA
Yep it seems it doesn't support C2D!
well that makes the decision much easier, I think i'm going to wait till that new processor intel is coming out with in Q4 or Q1 in 2009 starts with an N.
hah
Thanks for the help guys
