- Nov 24, 2011
Photo Album:
Parts:
* Bracket from 56K modem
* Scrap aluminum bar
* Simpson Strong-Tie 5-in 20-Gauge Galvanized Steel Tie Plate Wood To Wood (TP-35)
* Nylon standoffs/spacers
* 3 ceramic cement 20Ohm resistors
* 2x100W TPA3116 D2 Dual Channel Digital Audio Amplifier Board 12V-24V
* DC-DC Boost Converter 10-32V to 12-35V 6A Step Up Power supply Module
* 18 AWG wire (Black/White, i do not have red or yellow wire)
* Zip ties (4 and 6 inch)
* ferret core
* insulted spade connectors (tired of dealing with molex plugs)
* heat shrink
* 3M stainless steel scews/nuts/washers,lock wasters
Had issues with the system rebooting when the amp is turned on so that is what the resistor bank is for
Bent one edge of the stong-tie to add rigidity
Hoping the ferret core will remove the hum from the speakers when not in use (very tolerable if it does nothing)
Speaker wires run through opening in the bracket to the amp board
This monster is going to live in the top PCI slot where I do not have a PCIe slot cause of a M.2 port, the boost converter just clears low profile addon cards
It does sag a little, it pulls around 0.25A when running
Attached are heavily cropped image with background data removed to make the files under 2MB
Parts:
* ferret core
* heat shrink
