- Jul 26, 2009
I currently have an HP LP2475w calibrated with a Spyder3pro which I use for primarily for photo editing, but also everything else. I am looking to add 2 side displays, but do not need the same level of quality as they will just be used for secondary programs, tool bars, and non-color-critical applications.
I would like to get 2 20" 1600x1200 displays but nobody makes a "consumer" level version, so I am looking into more standard "consumer" sizes. I want at least 1000 pixels wide and 1200 tall, which leads me to a few options:
21.5-22" 1920x1080 maybe portrait?
23-24" 1920x1080 maybe portrait?
The level of monitors I am looking at are all between $130-$170 for all sizes so price is irrelevant
Since I am not going for the surround gaming experience, and sit fairly close to the screen, I am thinking that putting 3 widescreen monitors side by side
in landscape may be a bit too wide, but dont have any way of trying it. Has anyone who is using multiple monitors for productivity, not gaming, had any experience with any of these combinations/orientations?
Since the prices are so close, I find it difficult to go with the smaller displays, but am not sure if the height differences will be annoying or not. Any thoughts?
I will be building an angled support to mount my monitors and speakers so I will be able to position them however I like relative to each other.
Since I currently only have a single 260GTX, I will need to add another video card. Can I just pick up something cheap with 2 DVI ports or will having 2 different video drivers installed be a problem?
Thanks
Thanks
