- May 29, 2002
- Japan/Daytona Beach
when i build a new comp i will want it to run very quiet.
of coarse it will be water cooled but if im gonna get the best rad/core im also gonna want the quietest fans for them.
i hear paps are great but some of the fans i see are at like 30db and i want to get the sound down into the teens or low 20s
i know lower speed means lower noise but it also means lower cooling too so i want to find a balance.
i was thinking about putting a couple of 20cmf paps fans in the case and on shrouds for core but i dont know if it will do the trick. im not planning on OCing just want great cooling with no noise for todays hot procs . ( ok so i might OC just a little but not much)
oh for the limiting factors .
i dont have the ability to shop around where i live or do any kind of real work on the system parts so i have to go pretty much mainstream orders that ship to japan
anyways my idea is to get a large aluminum case like a lian li (i will probly go dualy )
get tygon tubing
get a Radiator
get a waterblock ( probly a whitewater or one of igors jobbies)
get a pump ( need GOOD pump that is quiet and have no clue about which is quiet )
get a reseviour ( want something that is cylinder shaped and clear because it looks kool)
get the fans
ok now i saw about a year ago a website somewhere hat let you listen to the fans on your PC. does anyone remember what site that ws and if there is one for pumps also ?
and what are your recommendations for pars ?
get tygon tubing
get a Radiator
get the fans
