This is a nice and inexpensive memory kit that I wanted to test some more.
General specifications:
Product Photos:
The Zenith memory kit contains two 16GB, dual-rank modules. The memory uses new series of Hynix IC. As you can see below, Thaiphoon Burner can't read it but it's scaling like a new A-die. Regardless of what is under the heatsinks, the most important is how it works.
There were no problems with stability or compatibility on new motherboards with AMD and Intel chipsets. However, I'm using higher series motherboards so I can't guarantee that every lower series model will be problem-free.
There is only one XMP profile but it works fine on AMD and Intel motherboards. At least ASUS, ASRock, and MSI motherboards had no problems with the profile.
So far I started this thread but will add some results later.
Product Photos:
