Simple boot guestion
Big_Tex
texas
Ok I had xp pro installed hated so i went back to 2000 pro everthing went fine win loaded everthing correct.But when i reboot it says boot 2000 or win xp pro.I dont have xp pro installed now so how do i get rid of the option menu so it just boots to 2000 pro without the option to pick which one.
ThePerfectCore
Red Raccoon Dojo
Texas
Open up boot.ini in the root directory, and remove the line that has the WindowsXP Pro label in it. Be careful to remove *only* that line.
If you don't like doing that, you good go Start->Settings->Control Panel->System->Advanced->Startup & Recovery, and under System Startup, set the time to wait to 0 seconds, with Windows 2000 selected as your default OS.
