- Jun 25, 2001
This should be an easy one for you guys. Right now I have a generic 80mm fan in the rear. I am planning on getting a better fan for the rear but not sure wha I can do in the front. In the front there is a spot for a 80mm but the only holes in the front consist of a 1" space at the bottom of the case. Can I put a fan in there, and how much air would it draw just from that space. Also, if I can put a fan in there, should I use a fan of the same or different cfm as the rear. Oh yeah 1 more, can you, and will it improve cooling to change the fan in the PSU. (Enlight 300w). Thanks Guys
MH
MH
