Single and Dual Channel mixing
SilverJag
Chicago, IL
Hey,
I have two Mushkin 222 256*2 in Dual
I plan to put in another brand of ram 512 RAM in Single channel, it will probably be OCZ but will it affect the overclockability at all? All comments welcome.
You can not run both single and dual channel at the same time.
If you really want more than 2x256 then I would sell those two and get another 512 with the one that your buying.
For me 2x256mb of Mushkin would be enough though. All depends on the things you do though I guess.
Yes you can run both dual channel and single. I posted a thread regarding this.
And a gig would be good for future games and if you use programs like Photoshop a lot.
Back to the original question:
Your OCZ most likely won't be able to run 2-2-2. If you really want ot use it with your BH6's, you'll have to loosen the timings.
