Single card to equal dual cards
Remove
I currently have 2 8800 GTS 512mb G92 cards in SLI in my gaming rig. What would be an equivalent/better single cards soulution?
freeagent
Winnipeg!
A 285 should rock the casbah.
But not too many people would reccomend getting one, and would probably mention ATi :thup:
CharlieCS
By the time fermi is out , there going to be another better card in the pipeline , so its irrelevant:blah::grouphug:
5870 should outshine two of your cards by a significant margin .:thup:
P.S. sorry for liberal use of smileys i just realized we got a bunch of new ones , to bad still no dancing banana.....
Remove
Remove
I'm way past the days of paying for the newest and fastest. A $400 card I'm not going to get. I should have said so earlier.
I'm very happy with the 8800s and am looking for Nvidia. I have just had better luck with them, hence why I posted in the Nvidia forums. :D
I'm just thinking of downsizing to a micro atx form factor, smaller case and thus single card.
What about a 260 GTX? Equal?
Remove
Remove
:comp:
Saw the new smileys also so dropping a cool one in as well.
freeagent
Winnipeg!
A 260 should do you well, maybe even a 275..
There is a 280 in the classies :thup:
And hey u ati guys, dont make me come to your backyard!!
:sly:
CompuTamer
Member with Some Fancy Text Under His Name
Brandon Mississippi
:comp: He's probably using that 5870 and eyefinity ;) lol
I'm not too good on the Nvidia side... i can recommend ATI stuff to you all day long though :D
A 4870 or 4890 would probably do what you want it too... or a 5770 would also give you DX11 support with about the same amount of power if i recall correctly.
Remove
Remove
Really look like I'm in the 260 to 285 range as far as needs. Now I just need to find some good deals. Making offers on a few things in the classys too. :D
Zantal
if you go for the 260 make sure it's the 216 SP version, much better than the 192 one =)
