- Feb 15, 2001
- Harford, WI.
One thing I notice is a lot of people think you have to have a second PSU to run a peltier. Well from my own experiences and beliefs. You only really need a second PSU to run a peltier if your psu is around 235w to 300w's. Anything bigger and there should be no reason for a second PSU to run the pelt reliably in my opinion. Of course this all depends on how much other hardware you have as well how big the peltier is.
But for the most part if you dish out the money and buy a big PSU that will push a lot of amps you do not need a second PSU to run a pelt. My 431w Enermax with all my hardware below, slot1 Alpha and 3 80mm case fans runs the exact same voltages with or without the peltier! The number are pretty well the same.
I know as far as stability and less chance of shorting your system of power at bootup (which is one of the biggest problems of running a peltier on a small PSU) it is a good idea to run a second PSU. But I think it is a misconception that it is needed to run a pelt or else you will have problems! Well this is not really true.
I just wanted to express my opinion on this. As I used to believe it was needed as well till I ran my 250w PSU alone with a pelt and all my hardware for around 6 months before I had any problems.And the problems that did arise were due to a power surge(which wrecked my modem as well). I know I will never have to worry about my Enermax giving me any troubles!
