Can anybody tell me the size of the Hercules MXII card from the back of the agp slot to the back of the card? I would like to know if I can fit one into my system...
I think he's referring to "overhang" past the end of the AGP socket, in which case the answer is none. The card "ends" at the end of the AGP socket itself.
Mr. B, did you actually look at your card or are you guessing? My Hercules 3D Prophet II MX extends past the AGP slot by about 1 inch. But, I bought mine early last fall, are the newer cards that are out now, smaller?
batboy (Apr 18, 2001 06:13 a.m.):
