- Feb 15, 2001
- Harford, WI.
I dont want to run my watercooling system inside the case due to heat building up with the use of a peltier.
My question is, How big of a water pump will I need to push the water about 2 or 3 feet to the cpu and then the same back? Will a 200gph inline be enough or can I go smaller yet.
I will be using an 86w peltier on the cpu in conjunction with the watercooling. Also I figured with the use of a pelt. It would be better to have the radiator outside the case, so it could cool the water better. The pump, Radiator, and water tank will all be inside another box a few feet away from the pc. But it will be sitting about level with where my cpu is on the board. So it will actually be traveling straight across and not up or down.
Any suggestions are appreciated. Thanks in advance.
