sk-6 would be easier for me imho but the 8045 droppes more temp. either one, im moving everything into my new chieftec case fith 4 80mm fans so that will help. plus the sk-6 is 20$ cheaper. just give me which one you chose and why please. thanks
go for pal8045 i'm getting one and i'm owning a sk6, it costs under 40$ with fan and shipping included. is not that expensive just 10 bucks more and the temperature drop is important
The Alpha provides good cooling a low noise levels cause of the 80mm fan. Or if you don't mind the noise you may always slap on the 80mm Delta and get temps which are near to Watercooling.
The SK-6 is nice and works fine and is very reasonable priced...
But only reaches Top performance with a Delta screamer.
So, if the price isn't a problem, go for the Alpha...
