you need to see how far apart the cards are on the motherboard. if you have enough pcie slots on the board you could use the medium one so they have some breathing room.
with the short one they are basically sandwiched together and the top card will always be hotter (and throttle earlier so it will slow down the cooler one also) check your motherboard manual, it may be stated in there which configurations you can achieve.
The appropriate sli bridge should have been packaged with your mobo
The bridge that came with an Asrock Z170 Extreme6 that I'm using for a build has the medium size.
