SLI or Crossfire: vendor specific code?
magellan
When a games developer codes a game to support Crossfire or SLI is the codebase for each path pretty much the same? Or mostly vendor-specific?
Janus67
Benching Team Leader
Do you mean between Crossfire and SLI or between games? The code for each are different, otherwise all games that supported SLI (or Crossfire) would also support the other, but that isn't the case.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Logic. Gotta love it!
M
magellan
So there are games that support one or the other but not both?
M
magellan
Yes, just as it has been for many years.
So the code to do SLI isn't the same as the code to do Crossfire? They each have their own API?
Will DX12's multiadapter mode make SLI and Crossfire obsolete?
Janus67
- Correct
- Most likely an API to hook into their drivers to tell it that it supports Crossfire and how to split rendering/etc
Will DX12's multiadapter mode make SLI and Crossfire obsolete?[/QUOTE]
- Maybe, depending on if/when developers code for DX12 multi-adapter as it isn't automatic. It will also be a very long time before games will be DX12-only, thus any games that the devs want to support multi-gpu and are also coding in DX11 would have to code for SLI/Xfire.
