Hi all,
I don't particularly overclock my PC, except for what was offered to me in the BIOS in terms of a simple level up. Even though things are running absolutely fine, I used CPU-Z to check out what memory I had with my build from the bundle I got (having stupidly thrown the packaging away), and then I grabbed an extra 4GB second set of RAM modules that were (I thought) exactly matched to what I had. They are a little different (see links below). I am about to get a Samsung 830 SSD and I have these two very similar pairs of modules installed. They have a slightly different latency. I have not noticed any problems but thought I might ask if this is OK or may lead to issues? I thought they would both just run at the slower speed but I probably am a little out of my depth when it comes to the nuances of memory. You all seem like a great bunch and I look in on your conversations regularly, so thought I would ask you my question about this.
The two types are:
http://patriotmemory.com/products/detailp.jsp?prodline=5&catid=34&prodgroupid=200&id=855&type=1
and
http://patriotmemory.com/products/detailp.jsp?prodline=5&catid=34&prodgroupid=200&id=856&type=1
If you need lots more info about my rig just let me know and I can post the relevant details.
Thanks in advance!!
The two types are:
and
Thanks in advance!!
