SLK 800 or CoolerMaster IHC-L71
trex
which one is better slk 800 or CoolerMaster IHC-L71? also with slk 800 which fan that would perform best?
Fever
Montreal, Canada
SLK for sure man. A tornado 84CFM seems to do really good with that HS, but then again which HS wouldn't? ;) If you value your ears though, pick up a 50 CFM Sunon, or something a bit more quiet.
SLO_N8
PA, USA
Yep, SLK-800 & the loudest 80MM fan you can stand is an unbeatable air-cooling solution @ this time :)
Caffinehog
Übercaffinated Member
In the lab
Well, the SLK-800 really needs lots of air for performance; a 50cfm sunon is going to have trouble pushing much air through all those fins. With a lower powered fan, the best heatsink available is really the AX-7. And these can be found dirt cheap at many websites.
eli
Alpha's 8045 does pretty good with the moderate CFM fans, but for the price you can get a bit better performance with an AX-7.
