SLK-900 w/120mm
bafbrian
Atlanta, GA
I was readin cmcquistion's article on the front page about building a silent PC. I saw how he mounted a 80mm fan on the SK-7. It got me to thinking, could you possibly do the same with a 120mm and a SLK-900U ?
THX for *see avatar*.
you could get a 80-120mm adapter and use a 120mm fan, but the performace stink since 120mm fans dont have the static pressure to push a decent ammount of air though a adapter and a heatsink. basicly, a 80mm fan running at the same noise level would give you better results. and i say this from experiance, ive tried it and was disappionted.
