I am using XP .. with a 2.0 ghz amd athlon xp , with 512 mb ram .. blah blah
Since you seem reluctant to post your
complete system specs, only noting that you have a 2.0GHz processor, 512MB RAM, and are running XP...I'll take a wild guess and suggest one or more of the following files is either missing or corrupt:
Stdole32.tlb
Stdole2.tlb
Stdole.tlb
If one or more of the above files is missing (this also applies to replacing the corrupt file(s) with a known good copy), you'll need to expand (extract) the appropriate file(s) from the XP CD by clicking Start | Run | Type
CMD and hit OK. To change to the root folder of drive C, type
cd\, and then press ENTER. Insert the XP CD, type...
Expand cd_drive_letter:\i386\filename.tl_ drive:\Windows\system32
...and then press ENTER, where
filename is the name of the file you want to expand, and
drive is the letter of the drive on which Windows is installed.
