Slow loading...VIA the culprit?
PCphreak
Dayton, Ohio
I have a Maxtor 80GB 7200 RPM drive. It's the only drive on the 80-conductor ribbon and XP® is detecting DMA. The chipset is VIA's KT266a with 256 MB DDR. XP® is tweaked with bare minimum services running too.
Now my gripe.
I invited my brother-in-law over for a 2 person LAN:D. He has the SiS 735 chipset (ECS board) with 512 MB DDR and 80 GB WD 2 MB cache.
When playing Battle Field 1942 for instance, he is able to load a level map about 30%-50% faster than I. His system is non-overclocked too- (not that bus bandwidth is an issue).
I've noticed my loading times with games being irritatingly slow, before this head-to-head comparison.
I'm thinking with having only 256MB RAM, Windows XP® is creating a swap file when this game data is loaded, slowing this load time down. Am I correct in needing more RAM, or is this typical and VIA is to blame?
-PC
RED Hot Machine
Inactive Moderator
You hit the problem on the head.
2k/XP both run alot faster with 512mb of ram. I had a stick die on me a few months back and am down to 256 now and there is a big difference.
Get yourself another 256mb stick and you will see a difference in loading times.
A big thanks to Microsoft for making there software so bloated :rolleyes:
PCphreak
PCphreak
Dayton, Ohio
Thanks for the input...I thought by tweaking/trimming XP® would negate the need for another 256 MB stick (as I was going for max FSB). Well, tweaking did to a certain degree- as it's quick for all around use with the 256 MB (except large data loads of course). Looks like another 256 MB stick will be on order...
I'm considering a 512 MB stick...I'm assuming a majority of 768 MB total would go unused, correct?
-PC
RED Hot Machine
Inactive Moderator
The amount of ram used all depends on what you are running. Windows will start to cache programs/system files etc.
This all helps to make windows run quicker. When I had 512 I was getting about 400mb+ used and with 256 I'm getting about 185+ used, windows loads and unloads programs as i see's fit.
Windows will make use of the 768mb of ram, you should see less disc access which should speed things up :)
Can you buy me a 512mb stick aswell :)
PCphreak
PCphreak
Dayton, Ohio
Ok, I'm not really apt on how Windows XP operates. I assumed as long as you controlled the amount background services, you controlled a majority of how much RAM would be used. I do remember the talk of how XP manages large amounts of system RAM better than previous Windows versions though. I also know Linux avoids these types of issues....In a catch 22- so to speak. I would like to run Linux, but Windows® has everything I use.....
-PC
RED Hot Machine
Inactive Moderator
Have you thought about a daul boot ?
You could have windows xp and linux installed. That way you get to learn about Linux but still have Windows there for stuff you can't/don't know how to do in Linux.
PCphreak
PCphreak
Dayton, Ohio
I considered that for the sole purpose of learning Linux- but until Linux becomes an almost drop in replacement to Windows®, looks like I'll remain possessed by the 'Evil Empire':D....
Although I am curious/excited about the direction .NET is taking with a Common Language Runtime....looks like Linux usage may now be closer than anticipated for me.
-PC
