SOLVED SM Bus Controller Driver Borked?
RollingThunder
Destroyer of Trolls & Spammers
Had a little hiccup on my DFI DFI DK P45 T2RS Plus board in my sig with a “Driver not loading” popup box on a reboot.
I checked Device Manager and SM Bus Controller apparently is borked as there is a yellow exclamation by it. This is a new one for me and I’m not sure of the procedure or even what file needs to be downloaded and reinstalled from the Intel site. I’m not even sure of what Intel chipset I have from the Intel site or if this is even the proper place to look:
https://downloadcenter.intel.com/product/1145
Everything seems to be working OK so far.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
SM BUs controller is used to monitor voltages and temps on the board IIRC.
Have you tried installing the chipset driver from the board's website (Its DFI, does it even have one?).
Your chipset is P45.
satrow
Cymru
There was one SM Bus controller that was installed by ASUS (possiibly also Gigabyte) that caused BSODs for some, me included. I spent years with that yellow mark and no ill-effects.
ASACPI.sys
Version/Time: Sat Aug 20 14:04:18 36005
Basic Info: Asus ATK0110 ACPI Utility (a known BSOD maker in Win7 and Win8). Also a part of many Asus utilities (Win8 versions available from Windows Update as an Optional Update - but check Asus first!)
Driver Source: http://support.asus.com/download/download.aspx
http://www.carrona.org/drivers/bsod_drivers.php
Mr.Scott
Beamed Me Up!
You can always message me for DFI and other defunct companies. If I don't have it here I can usually come up with it. :)
