SMP Core Shutdown Error
Giz
Crewe, U.K
Has anyone seen this shutdown message before? It's happened twice in the last 12 hours.
[20:17:00] [email protected] Core Shutdown: INTERRUPTED
[20:17:04] CoreStatus = 66 (102)
[20:17:04] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (15)
[20:17:04] Killing all core threads
Shutdown requested by user?
My other PC has ran for the last 48 hours since VMplayer install without any issues at all. This PC needs constant checking even though the installs are the same. The VMplayer network connection keeps dropping too, but this is something else?
I.M.O.G.
Glorious Leader
Rootstown, OH
Sigterm 15 is a the default kill command for processes. Something is telling the process to shutdown - sounds like you have some sort of instability. Are you familiar with Linux at all?
I'd start checking out some log files. Let me know what you get from the command "ls /var/log/" when run from the terminal, and I'll tell you which ones to look at for errors.
Giz
Giz
Crewe, U.K
Thanks for the reply, I.M.O.G.
I'm new to Linux, only installed VMplayer and Ubuntu the other day. Opened the terminal and this is what your comand gave:
If you can't see the text very clear it's:
Code:
 [email protected]:~$ ls /var/log/
apparmor       dmesg.0         kern.log.1.gz  syslog.1.gz
apt            dmesg.1.gz      lastlog        syslog.2.gz
auth.log       dmesg.2.gz      lpr.log        udev
auth.log.0     dmesg.3.gz      mail.err       unattended-upgrades
boot           dmesg.4.gz      mail.info      user.log
bootstrap.log  dpkg.log        mail.log       user.log.0
btmp           faillog         mail.warn      wpa_supplicant.log
ConsoleKit     fontconfig.log  messages       wpa_supplicant.log.1.gz
cups           fsck            messages.0     wpa_supplicant.log.2.gz
daemon.log     gdm             messages.1.gz  wtmp
daemon.log.0   installer       news           Xorg.0.log
debug          jockey.log      pycentral.log  Xorg.0.log.old
debug.0        jockey.log.1    samba
dist-upgrade   kern.log        syslog
dmesg          kern.log.0      syslog.0
Giz
Giz
Crewe, U.K
Yes Jolly, using IPv4. There are two network adapters showing in Vista Network Center. VMnet1 and VMnet8. Both are active. In Status, both show IPv4 as Local and IPv6 as Limited.
Something else that's bugging me. How to install VMware Tools. It's ready to install, but the bottom message box is telling me to open a terminal window and use Tar to extract the installer. How do you use Tar in the terminal window?
Also, in the terminal window showing SMP work, is this message important?
NOTE: The tpr file used for this simulation is in an old format, for less memory usage and possibly more performance create a new tpr file with an up to date version of grompp
Jolly-Swagman
You can just hit install and will put CD icon on VM desktop and install from there or in VM options have install at next time you run VM
The quoted error ,,, Dont worry about that is old and not used any more just disregard
I.M.O.G.
Glorious Leader
Rootstown, OH
I'm not familiar with folding in vmware player, so I can't speak as specifically as someone else probably can.
However, you need to run these commands as root, or by using the sudo command, to follow the directions for using "tar" (tar is like zip, just a different format):
Code:
4.	Untar the VMware Tools tar file:
tar zxpf /mnt/cdrom/VMwareTools-5.0.0-<xxxx>.tar.gz
umount /dev/cdrom
Where <xxxx> is the build/revision number of the VMware Workstation release.
Note: If you attempt to install a tar installation over an rpm installation — or the reverse — the installer detects the previous installation and must convert the installer database format before continuing.
5.	Run the VMware Tools tar installer:
cd vmware-tools-distrib
./vmware-install.pl
Respond to the configuration questions on the screen. Press Enter to accept the default value.
