- Oct 12, 2001
- Los Angeles
Well it's that time again, a new build in the works. Finally got my custom UFO after a long 5 week wait. Note the color and the 3 SEPERATE panels for the sides and the top, no more clamshell one piece like my current case. This is the main reason for the switch, though there are some other cool little bits I'll be doing as well. I have the PA120.3 and the aluminum Coolermaster 120 x 38mm fans which I have tapped to accept normal threaded metal screws, I have chose black allen bolts. I think I will be tapping all fans and using these bolts all around as I like the look. Well, gotta run ATM but here are a few pics.
Sorry for the blur
the case now only uses 120mm fans
Test fitting of the PA120.3
Sorry for the blur... Screws (dont look as black as they really are here)
Sorry for the blur
