- Apr 19, 2012
Ah, well...now after about 40 minutes of prime95 I have CPU throttling. But my temps are at about 48. This just keeps getting better and better.
VRMs running a little warm perhaps? Actively cool them!
More vcore. Your chips a ****ty clocker, and what are your load temps?
I would try for more once you confirmed 4.4 being stable... Make sure you have good air flow on that rad!
Then you can fall back to 4.4 if you can't get it to budge...
I would use air from outside, because it looks like Asus AM3+ motherboards may be more finicky with temps than others and shut down at only about 65 C to about 70 C! Just a heads up!
Despite it shouldn't be triggered at that low of a temp... The shut down temp should be more like 80 C...
If folks were to think like the old school AMD days, then 8320s usually would be sucky OC'ers... (And 8350s better and 9590s the best) But we know that the 9590s are ridiculously ironic for having a tendency of clocking poorly...
Looks more like a poor batch, more likely if an early one. (anything pre-2014) (and 2012s are possibly the hardest to OC)
It they're anything like the old school AMD days, then the first Visheras (2012) are likely real finicky...
I had a 2014 8350 with a low VID...
Max temp directly from AMD whitepapers says 62c. Anything above that does damage. That's why they shutdown where they do.
I wasn't talking about the inner core temp sensor. There's 2 sensors and the other one is good to about 80 C with a little OC...
From what I had experienced with AMD and Asus boards was that the socket temp while board was set auto all would throttle processor at only 65c the core temps never seem to matter unless you reach that thermtrip temp of 85-90c. I found this out after a de-lid or two where I could get the cores to usually run hotter than the socket temp.
The point is running these FX chips past 65c (socket/board) is likely to create instability while overclocking.
My de-lidded FX-9590 does not like temperatures past 50c while running beyond 5ghz.
However I have seen higher socket temps on some people's set ups, but if you look closely there was either no or very little overclocking taking place.
FX needs the cold and this ultimately keeps your v-core lower also.
There is only one sensor on die. The rest are on the board.I wasn't talking about the inner core temp sensor. There's 2 sensors and the other one is good to about 80 C with a little OC...
And that sensor for me stayed cool. That wasn't the big problem... I usually had low readings, compared to the socket sensor, which is vice-versa from socket 462!
(The socket 462 sensors were a slow responding sensors that have trouble detecting sudden temp jumps) I did stop the shutdowns at a measly 4.4 by just sucking air from outside...
The Sabertooth 990 FX R 2.0 I used to have, hated room temp air!
