The short answer is: no.
There is some discussion and links in the Math thread titled
AKS - A polynomial-time algorithm for testing primality.
The main significance of the AKS algorithm is that it is the first *provably*
polynomial-time scheme for proving primality (or not) of any desired number.
That doesn't mean it's necessarily faster in practice than schemes such
as ECPP, which are polynomial time for nearly all inputs (and many such schemes
are in fact polynomial time for ALL inputs if the Extended Riemann Hypothesis
is true - it probably is, but AKS doesn't need it to be). And for numbers of
special form (e.g. Mersennes, Fermats, Proths, etc.) there are well-known
deterministic primality tests that are not only polynomial time, but also
much faster than AKS, ECPP, etc. So don't expect to replace Prime95 with
anything else just yet.
Cheers,
-Ernst
if that didn't make any sense to you, just think that there are very fast ways that 'special' numbers like mersennes can be checked. The downside is that you can ONLY find mersenne numbers (or other similar numbers) with this special algorithm, but you can still find larger numbers faster.
This new way is an algorithm that'll find if ANY number is prime, but while it's faster than checking all the primes less than the Square Root of the number in question, it's not nearly as fast as P95 at checking mersenne numbers in the special form (2^k)-1.
