Nolukjustskil
- Feb 2, 2016
Ok I plan on building a wooden pc case for my system and its going to be watercooled.
I havent started it yet, but its going to look similar to this http://www.ibuilditaudio.com/Projects/computer/computer-case-4.php
Except its going a be a little larger, have 2 360mm rad holes in the back(he has a 140mm fan). Since im building watercool peice by peice im gonna use my 120mm cpu AiO for now and upgrade to a 2nd 360mm rad with push/pull fans in the future(gonna use 2 120mm fans with cpu cooler to fill in the holes for now. I am also going to build a fan tray that sits in the bottom to pull air in (its going to have a furnace air filter on it(guy showed a 1 year later opening and had almost 0 dust in his system)
My few questions are should I mount the res outside the case or would it be fine inside? Any suggestion for wood types? Figured something that works well with heat and a little moisture. Do I have to set up push/pull on my rads or do you think their will be enough airflow to keep everything nice and cool?
Thank you for your time
