- Sep 20, 2001
- Bakersfield, CA
This is the second one I've seen in the last two weeks.
I was going to get a laser pointer ir temperature reader gun to check the power plug temperature while gaming but after reading some reviews it looks like they aren't pinpoint accurate enough to check tiny spots.
Define too expensive? Have you seen the Flir ONE models that connect to a phone. ~$200. I think I have an older gen version.Thermal image cameras are too expensive.
Sure. $200 to check on some wire temps occasionally? Way too expensive (for me - for personal use - for OCF.......I'd buy it). I 'own' a 5090 and won't be buying one.Define too expensive?
You think... lol. Link?There was another case last week I think. But still very rare.
The failure rate is much below HDDs![]()
Just giving the option in case it is of interest to anyone. It's not like you can only use it on GPU cables. It's a tool that can be generally used if you want to, and the pricing isn't a major barrier now it is in consumer level with these phone connected models. No more do you have to look at 4 figure price tags for "professional" models, although they can give more features for that money. In the context of the PC space, it's not that big a spend.Sure. $200 to check on some wire temps occasionally? Way too expensive (for me - for personal use - for OCF.......I'd buy it). I 'own' a 5090 and won't be buying one.
Not saying it isn't a good deal but I don't want to spend more than 20 bucks or so on something I'll probably never use again or seldom at bestJust giving the option in case it is of interest to anyone. It's not like you can only use it on GPU cables. It's a tool that can be generally used if you want to, and the pricing isn't a major barrier now it is in consumer level with these phone connected models. No more do you have to look at 4 figure price tags for "professional" models, although they can give more features for that money. In the context of the PC space, it's not that big a spend.
Fully aware there are other uses, but it just isn't anywhere close to worth it for me at $200. $50 maybe... lol.Just giving the option in case it is of interest to anyone. It's not like you can only use it on GPU cables. It's a tool that can be generally used if you want to, and the pricing isn't a major barrier now it is in consumer level with these phone connected models. No more do you have to look at 4 figure price tags for "professional" models, although they can give more features for that money. In the context of the PC space, it's not that big a spend.
