- Sep 7, 2003
- Warsaw, Poland
QijdiDeOr said:Never Gin!!!!! * goes French for a moment *AreYouMAd? Never Jinn in a martini!!! Only Ze Fienest Vodka An only potatoe........
HAHAHHAAHAHAHAH
Are you European?
HAHAHHAAHAHAHAH
I forget which but it has a "normal" hub. If you'd like I can do a side by side my Sunan Tornado. The hub is the same size as a standard 80mm fan but its very deepMVC said:Sentential, is that the 25mm or 38mm 3-blade Delta in the pics? In this pic, it looks to have a "normal" sized hub so I'm wondering if it's the fan or the pic (or possibly me just not seeing as well as I used to). Maybe I should just order one of each and take a look at them.
Sentential said:I forget which but it has a "normal" hub. If you'd like I can do a side by side my Sunan Tornado. The hub is the same size as a standard 80mm fan but its very deep
Im telling ya man, the majority of the HSF is a good 2 inches above the base. It *will* fit.QijdiDeOr said:Sentinel> Thanks... I will confirm with Thermalright and let everyone know - It looks like it will fit my board despite the size - we will see.
Qij.
LOL... you wouldnt have been the first person to say that to me. Just dont see any of my review threads otherwise the same thing will happen lol Congrats on your new purchases.MVC said:Sentential, I've decided that you're a bad influence!!!
Sentential said:LOL... you wouldnt have been the first person to say that to me. Just dont see any of my review threads otherwise the same thing will happen lol Congrats on your new purchases.
Good stuff however did you buy the LGA775 adapter or not? You *DO* need one to use itQijdiDeOr said:Good News...
The folks at Thermalright.com
1-909-597-7003
Say that the XP90 will fit fine - so here we go.... At the current masure of case4 height I have enough clearance for either the 120 or the 90. Due to Monetary status I must go with the XP-90 till the next flush and I can do Water. The XP-90R Retail package is priced very reasonably and comes with fan - that will be used as a case fan for I wish for more gusto.
I will place a Delta 92x38mm TFB0912GHE Extreme High Speed Fan on a front slot fan controller card I found on Garage sale clearnace on another site - Too bad I have to go there but this is costing enough already when watercooling is the next step. This way I will already have a 92mm fan for the radiator when it arrives.
In the mean time.... It should be about 3 days before everything arrives and I will be sure to inform whether success of failure...
Qij.
