Socket a mobo with best vcore adjustability?
dalilman52
Houston
i wanted to know which mobo for socket a with nforce 2 chipset like a7n8x dlx.....has best vcore options, i know the a7n8x only goes like .3v over stock or something low like that...any other brands let u go higher? like maybe...1.9 vcore?
btw i know this isnt the amd board section but im not about to post a thread in every manufacturer's section...
I have the abit NF7-s v2.0 and I can change it to pretty much whatever I want. And you can go well over 2.0volts.
I am also pretty sure the Chaintech has good voltage options for everything. I think it was 2.3vcore, 1.8v vdd, 3.2vdimm and, 1.7 or 1.8 AGP though you usually won't change the AGP. Klownin79 has one (I think). You should ask him about his experiences. I think the DFI also has good voltage options but I can't say for sure.
NF7-S Rev2 goes up to 2.3 on vCore (although above 1.9 it can fluctuate a lot), 1/7v on the NB, 2.9v (usually overvolts) to the memory, and 1.8v to the AGP.
