Socket F, need serious watercooling...
TheQuadFather
TheQuadFather
Hampshire, England
thanks, i will look into that because some socket 939 coolers fit am3 so in theory i could fit a am3 cooler to socket f? sounds farfetched but its worth a look into
jaymz9350
A quick image search shows it looks more like 939 than the AM series, meaning it has 2 bolt holes instead of 4 (I don't know if the brackets and spacing are the same though). It would need 939 cooling for a bolt through mount assuming the hole spacing is the same.
Conumdrum
Small town Emlenton, PA
Look at the Danger Den TDX. Jeremy can make a custom top for it with measurements. I think the TDX would be enough cooling for that CPU. It's not a bad block for 150 watt and less CPUs.
I don't know much about that CPU though, I'm an Intel guy for a while now.
