Colin (Jul 11, 2001 11:34 p.m.):
Read this
review. Obviously all socket thermstor based HS reviews are bogus. The other not so startling revelation is how poorly the Thermoengine performs. A slick piece of marketing it is, but it does this by fooling the socket thermistor and all of the inept reviewers that rely on the socket thermistor.
No comparison to the socket thermistor is given in the review, so the relation between that and the readings presented is unknown.
The Thermosonic performs closely to the other excellent HSFs (like the Alpha PAL6035), outstandingly good for an all-aluminum HSF, and it performs similarly, if not quite as good, as in tests that use the socket thermistor.
The review says:
"I recorded the ambient temperature around the heatsink using a second thermisitor while the testing was taking place. "
If this is what he did, then the temp difference depends on where the probe was positioned in the air flow from the HSF. Some heatsinks distribute the airflow differently than others, and the temp of the air coming off different sinks is different. In particular the air from heatsinks with a low air flow is hotter than others with a high airflow, so this positioning of the probe makes low air flow heatsinks look better than they would if actual ambient (room temperature) is used.
"To test the sinks I used a Dremel to drill a hole directly through the center of the heatsink where the core touches the bottom. If there was a clip in the way, I drilled through it too. "
Of the Thermosonic:
"The version used here is the one without the solid core, one of the very first versions. "
The unusual center of the Thermosonic perhaps performs some function. Drilling through it could affect the function, if he actually did that. If he did not drill through the center, then he measured the temp of a different part of the core.
"I then used a tiny dab of super glue to hold the thermocouple in place (the hole was so small it held itself in place for the most part). This made sure the tip of the thermocouple was touching the top of the core to get an accurate reading of the temperature."
In any case, drilling through a slightly different spot on different heatsinks measures the temperature of different parts of the core.
Drilling a hole in the heatsink creates a hot spot where the hole is, since that part is not in contact with the heatsink. The hole is small, but so are the .18 micron transistors, and heat conduction along the very thin cross-section of the chip is poor. Significant distribution of heat along the surface of the chip is provided only by the base of the heatsink. The expectation that top-of-the-chip measurements give the true temperature (whatever that is ) is not obvious to me.
I don't know that the Thermosonic fools the socket thermistor any more than, say, the Hedgehog or the Alpaha PAL6035. Although it might, I see no reason why it would. Blowing directly on the chip is a good way to cool it directly and does not qualify as "spoofing" in my book. One could equally well claim that blocking airflow around the chip, which most designs do, is a HSF design defect.
If I recall correctly, Anandtech or Tomshardware, quite a while back when the Thermosonic was new, did tests with a synthetic heat source and and on-the-heatsink thermistor that confirmed the rank of the Thermosonic as near the top at the time, pretty much debunking the idea that the in-socket thermistor is "spoofed".
