Soft restart - XP
microfire
How do I do a soft restart under windows XP?
With windows 98 I use to just hold down shift while clicking restart.
I work with XP and I never used the software restart with a keyboard combination yet. pushing the on/off button quickly will however put your system into a restart :)
Mithrandir said:
Go to your taskbar
Start /shutdown/restart
I'm not quite sure what the keyboard cobo is
Hope this helps
Not at all.
Everyone knows how to restart their computer.
I want to know how to do it without doing a full hardware restart.
In XP, there is no soft restart, at least not to my knowledge.
98 is based on a lot of DOS code, thus you can exit Windows and enter a DOS only prompt. In 2k, XP, 2003, you cannot exit Windows completely into a DOS prompt, and restart Windows with a "win.com" file like older Windows.
