SOFTFsb on Tyan Trinity 1857-b
J
jason
Guest
has anyone had any luck with this or any other type of OC program with this board, also I can't seem to find the IC Clock on the mobo does anyone know what it is...Tyan makes a great board...unfortunately everything is stable at 83 mhz (it's a pretested 366/550 that works on an ASUS P2B but that's being saved for a Celeron CCo 600/927 because of the limited choices (like I said it works at 550 until I try my dvd decoder or access Sandra on the AGp part..in 98se but it's ok in 2000...I think I could get a bit higher if I had a choice in between 83 mhz and 100...
