SoftFSB Plug-in for Intel AN430TX Aka PB790
Treker
Old School Senior
Houston
Where can I get this, or have it made?
I am desperate, got a powerleap adapter, ordering a AMD K6-2 550mhz chip, have 6.0x multiplyer, just need higher FSB and this baby is set!
-Trek
Try to overclock your computer by choosing the right PLL-IC at SoftFSB. You can locate the number of your PLL-IC by looking on on your motherboard. If the PLL-IC you have doesn't support SoftFSB, then you may want ot download the right plug-in for your PLL-IC at http://www.h-oda.com/
wish it was that simple, but there is no plug-in for my chip
-Trek
Still no luck on O/C'ing this boards FSB , I would prefer to get it to 83mhz if possible, the chip should do that at Max.
I wish Packard bell wasnt such a cheap *** when building this computer, I could have used a few more damn jumpers, and for what I paid that should have been easy for them todo.
Shesh.
I'm looking toward purchaseing 3rd Party software to get this 430tx chip to run at 83mhz.
Cant find a thing.
ARg.
-Trek
