Beeing new to O/Cing, I learn new things on this board everyday. Something I don't see much on the boards are posts on software cooling, so I thought I'd share my experience with CPUIdle. I run a P3 500MHz wich has high idle and full load temps. In fact, both these temps are in the same range : 62oC to 64oC, no mather the load ! I've ask the board to know if these temps where normal for this system that is not yet overclock and the reply I got said that it was. I personnaly find that these temps must be lowered before I try to O/C my system, so I've ordered a golden orb (not the best, but certanly better than my generic HSF) that i'll lap and install this week-end.
One thing I found strange with my system was the lack of difference between idle and full load, but now that I use CPUIdle, I can realy see a difference. Mbm5 recorded a minimum of 31oC while Idle running the software cooler, but i think my average minimal temp is 38oC. Still, I think a 26oC difference between idle and full load can have a big effect on a CPU lifespawn. My (newbie) advice is that if you realy want to know how low your CPU temp can get, try one of these cooling softwares and if you'r not using [email protected] or SETI all the time, you could even increase your CPU lifespawn. I'll leave the "How does it work?" part of this post to our senior members. Gnight all,
