Can i use 95% tin or perhaps silver (low content silver, electrical solder) to adhere brass to copper? I will probably not be able to say what the specific alloy the brass is. Basically, i want to use brass (cheaper. stronger, more widely available) to enclose a cu heatsink and for a few other applications where it is not important that it conduct heat well.
On a related note, i'm sure i've seen reducers that let you solder (sweat as plumbers insist on calling it) 3/8" soft cu tubing to 1/2" water pipe but none of the little hardware stores that i've stopped in around here (nyc) have them or any 1/4" fittings (1/4 nominal fittings are supposedly compatible with this _actual_ 3/8" tubing of mine. They of course also insist that such a thing doesn't exist which is an interesting phenomenon itself and worthy of its own thread. No one ever simply says "sorry we don't have that" but instead try to convince you that never, in the history of the world has such a thing been produced... and by implication that by wanting it you are possibly defective. Anyway, i think i saw such a thing plumbing water to a laboratoy ice maker... perhaps i will stop by some refrigeration shops. but now, i will sleep.
OH yeah, thanks in advance.
