- Jun 27, 2015
- Madrid, Spain
Hi guys.
Much thanks to everyone on this forum that helped me build my WC PC. It crashes. It always did.
The crash:
As I´m playing the screen freezes instantly into the "average" color of the screen. If im getting a headshot its scarlet, if i´m in de_dust 2 its brown, if playing world of warships its blue, etc, if watching 300 its grey. Solid color always.
Specs
i5-4670k on Asus Maximus VII Gene
GTX 980 superclocked
16 GB Corsair Vengeance 1600MHz
2 Crucial SSDs
The part that is not from the previous build (it has the same crash) is the GPU, yet it appears that the graphics driver is crashing:
Odd right? My last PC had the same crash with an R9 280X on a different motherboard.
On win 8 i had to restart. On win 10 its recovering to the desktop, but I think its because I entered some registry keys. Some stuff about "time out detection delay". If i recall correctly it did not recover before i did that.
Meanwhile in Windows Application Logs:
There is a .dmp file which is beyond my understanding (typical me). I zipped it because it was over 585 KB. Its attatched.Event Viewer cant find the other txt and csv files.
/sfc scannow is ok
Ran memtest a few passes. 0 errors.
DDU. Then clean format. Discarded HDD. Discarded RAID issues in SSDs.
Inter Diagnostic tools fails PCH test. No clue why or what it does. Maybe I installed drivers wrong. I have no clue if I need Intel Rapid Sotrage or management Engine or any of that.
Also, I recently went into BIOS and enabled XMP ram stuff and it crased twice in a row today. I set ram speed to 1600 because that is what it said on the box. No clue about tested speed or working speed etc. Just 1600 MHz like on the box. My board scares me. It has a "teakes paradise" section I wouldn´t dare to open. Should I just do a CMOS reset and start scratch? Since this double crash it has brought me to think that it is a "general stability" issue although nothing is overclocked. Perhaps I have conflicting drivers or somehting.
Any clue? Thx
The crash:
Specs
2 Crucial SSDs
Code:
Event ID 4101; Display; Display driver nvlddmkm stopped responding and has successfully recovered.
...then:
Event ID 4109; Display; Application csgo.exe has been blocked from accessing Graphics hardware.
Code:
Event 1001; Windows Error Reporting:
Fault bucket , type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 0
Problem signature:
P1: 141
P2: ffffad8584cc94a0
P3: fffff802f7cc6b2c
P4: 0
P5: 2588
P6: 10_0_16299
P7: 0_0
P8: 256_1
P9:
P10:
\\?\C:\WINDOWS\LiveKernelReports\WATCHDOG\WATCHDOG-20180212-1841.dmp
\\?\C:\WINDOWS\TEMP\WER-166179015-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB878.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB878.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB889.tmp.txt
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_141_a2e7a6ad86560167878712c35f6b38575762416_00000000_21abb888
Analysis symbol:
Rechecking for solution: 0
Report Id: 4cc93d80-0262-497a-ae4c-ed46685cc930
Report Status: 4
Hashed bucket:
/sfc scannow is ok
Any clue? Thx
