Soltek SL-75KAV MOTHERBOARD HELP ME
LSDDSL
Im having problems overclocking my DURON 800mhz on this motherboard i have unlocked the chip with a HB pencil on the L1 section of the chip um the motherboard has got the MULTIPLIER settings from 5x - 12.5x The FSB ranges from 100mhz to 133mhz but in the bios it has an automatic overclocking utility and its **** it locks my computer so if anyone has anyidea of overclocking this chip past 920mhz than plz help me
Welcome to our forums. LSDDSL
Perhaps you could describe your problem little better we might be able to give you few tips.
Cooling ?
Psu?
etc..
Is it possible to turn tis automatic feature off?. Can you manually select the multiplier in bios, what settings give 920mhz? 8x115?
This board uses the VIA KT133A chipset. therefore it can do fsb 133mhz easy...
Yes the board does run the VIA KT133A chitset um i have a 300watt psu and they way i get the 920mhz is 110mhz fsb and 12.5 as the mulitplier
i know if u do the maths it works out to be 1.375ghz but the bios is funny u get ill type it exactly how the manual has it in here its um
RedStorm Overclocking Techh Press Enter
Auto Detect DIMM/ PCI Clk I have it set to the default which is enabled
Sperad Spectrum Modulated Its Disabled
CPU HOST/PCI Clock Which i have set to +10mhz
CPU VOLTAGE REGULATOR WHICH IS SET TO DEFAULT
um i have no i dear what to do here um im new to this stuff.
My system comprises of
duron 800mhz @920mhz
geeforce 2 mx 32meg
128 sdram PC 133
Creative labs sound blaster live
20gig hdd
60gig hdd
40x cd rom
8x4x32 burner
hope this helps u
This speed makes no sense to me. Sometimes if the cpu is not unlocked properly, only few multiplier settings work and others dont. If you dl sisoft sandra (downloads.com) It will tell you (cpu & bios information) what multiplier and fsb you are actually running.
Try to redo your pencil trick. This might fix this problem. However if your memory is good (PC133) you can overclock without using the multipliers, just by upping the fsb.
You wrote (CPU VOLTAGE REGULATOR WHICH IS SET TO DEFAULT)
this is the setting for cpu voltage, upping this might get you higher. You MUST pay attention to your cpu temps, dont fry your chip. Good cooling is the foundation for oc with AMD's.
Hope this hleps, keep asking.
Red storm overclocking is a neat idea but it is pretty optimistic. Don't use it if you are having problems. Make the settings manually. HB can spread out since it is soft, make sure you haven't shorted out bridge to bridge.
