Hi all,
From the currents posts i'm way behind. I currenty have an EpoX 8KHA volt modded motherboard and a AMD XP1600 1.4ghz cpu with 512megs pc2700 ddr. I've tried to unlock the cpu but while i was cleaning up the bridges i scrathed into the copper grounding out the L1 bridges so that didn't work. My system runs stable at 145mhz fsb i've had it up to 160mhz but its not stable. I'm not sure what the limits of this board is and i was hoping someone out their had a similar setup and might be able to help. I'm looking at buying a new cpu. What cpu would be a good recommendation. my mobo's multiplier max's out at 15. So i was thinkin some like a 2200+ which uses 13.5. I'm assuming that cpu is unlocked. Would i have to flash the bios etc..what are the pci divider settings etc... any help would be greatly appricated.
Thx.
Thx.
