- May 27, 2001
- San Diego, CA
Ok. I am set on the Danger den Setup. I am going to get the maze2-1 block that can support a pletier. Now i have an athlon running at 1.6ghz so i am 99% percent sure that i need a 156 watt pelt to cool this thing. Is this correct? Also i know i need some stuff to seal and protect my cpu and motherboard from condensation. What do i need and whats the procedure. I know that the pelt will lower my cpu temps big time but what will this do to the water( i will be using a DD cube with 2 120mm fans to cool). I have a enermax 430 watt power supply but im almost certain i will need another one for the pelt. Which one and where? Sorry for all of questions but i just dont like jumping into something so big without knowing what im doing.
Thanks,
MeK
Thanks,
MeK
