- Sep 6, 2003
I have a couple questions about adding additional hard drives and raid setups that i was hoping someone could answer.
First some background:
I have use up all the sata ports on my motherboard, but most of my hard drives are full So I am looking into my options. I don't really need the data redundancy of of a raid setup, but I do need the additional sata ports so I can plug more in. My understanding is to obtain those additional sata ports I will have to buy a raid card, however if I am buying a raid card, I figure I might as well setup a raid because redundancy is never a bad thing.
Here are my questions:
1. Do you have to have entirely new empty drives to create a raid or could I add my current drives to that raid without having to wipe them first. (3x 1.5tb drives, all with 150+TB free)
2.Once an array is created can I add drives to it to make it bigger? If so do all the drives have to be the same size?
3. Does anyone have any recommendations for a card? How much do I need to spend? They seem to vary widely in price. From what I have read I think raid 6 would be well suited to my needs. I was currently looking at this card. In the near future I am looking to expanding to at least 30TB of space if not more.
4. do I have to reinstall windows to use a raid card. (Windows 7 professional 64bit. Windows drive will be separate from raid and ran off one a mobo sata port)
Thanks,
Greyspectre
Thanks,
Greyspectre
