Some responses to my Cohesive Air Cooling Article
Actually Colin, I have been following yours also and wondered about the same thing. If the lack of heat reduction in the cube is due to too much resistance to airflow, a blower would do the trick. Like you suggested in a different post, varying the voltage would allow you to tune the air speed to the cube.
Hoot
HOOT?
I am really abnormal so I need some help on this. I will be building my own shroud for the same mod you did cause it ROCKS! Here are some links to my prototype:
The reason for the angle is because of a handle my case has...it opens like a door. Anyway I need some technical help. First, I assume the fan does not come with a 3/4 pin lead for connecting directly to your MOBO (-: How did you accomplish this? Second, you described a voltage regulator of some kind. To be able to adjust the fan speed with a switch I must know how you did this? Can you please elaborate in great detail and provide some actual pictures?
Thanks in advance...
mi1stormilst, that case looks very familiar... I wonder where I've seen such a thing? :)
I don't think Hoot connected the blower to the mobo, it would blow the mobo skyhigh drawing WAY too much voltage. The blower's most likely sucking the juice from his PSU, which is propably a very powerful one.
mi1stormilst (May 28, 2001 03:23 p.m.):
Yeah, how did you mod the fan's power connectors???
Hi Guys
There has been enough interest generated that I will write a Part 3 detailing the regulator construction, with lots of pictures. Hopefully, Joe has not gotten tired of publishing these follow-ups.
Time is not on my side as my Mom and Dad arrive this week for their annual 2 week visit. I only get to see them once a year as they live 1200 miles away. Add to that, the fact that I just concluded a Major mod project on my MC-462A and need to write that up also. It gets the cooling efficiency down to .10c/w using my Cohesive Air Cooling setup. The key is replacing the Aluminum pins with Copper Clad Aluminum pins. Believe me, it was a "Labor of Love", or Obsession. It kinda dims there. ;D
Anyway, get the parts in the schematic from the article, including a 2K ohm Linear Taper potentiometer with a long shaft and I promise to write an article as time permits.
On wiring in the motor, as the article implies, bring the two voltage leads inside the case via a pair of banana plugs and jacks. Until you get the regulator going, just splice the two wires to a 4-pin molex connector and plug it into an unused cable from the PSU. At 5V, it only draws about 1A. You could power the motor from an external varialbe supply also. Remember, at 12V it draws 5A, so pick an appropriate supply.
Hoot
You're the man now, Hoot :D
I'm eagerly looking forward to the article, but I hope you don't rush it. I'm sure all the electrical newbs would appreciate as detailed an article as you can muster.
This may be a real dumb question - but what ampage does the 12 v lines from power supplies run at........
Is there (and if so what) a danger of running it at 12 v @ 5 amps straight from the psu
Hoot,
Just another question, could you use the "dash board light dimmer" (real technical name there) as a regulator on this type of fan......
Judging from the number of lights one of these suckers regulate, I was wondering if they would be able to handle the sort of load going to this type of fan.
If you're talking about the DC version of the blower, no, it draws a lot more current than one of those rheostats could handle. In the case of the AC version of the blower, you are better off using a bathroom fan speed control.
Hoot
