Want some trivia to take with you to your next LAN party?
Heavy water is the stuff they use to cool nuclear reactors. Being the eccentric that I am I decided to contact some people and find out if its possible to get some of this stuff to use in my set up.
Here's a link to the website and people I swapped e-mail with.
Here is a copy of my e-mail and the questions I asked:
I am currently experimenting with water cooling my CPU. I am interested in the possible benefits of using heavy water in my system.
1) Is it illegal for private citizens to obtain heavy water for hobby use?
2) Is it expensive?
3) Can it be easily made in small quantities, ie 3 - 5 gallons?
Here is their response:
Hi,
I wouldn't think that the cooling capability of
heavy water would be different enough from normal
water to justify the cost. Heavy water costs about
$1500 per kg, and the cooling capability might be
only 10% better. (So 3-5 gallons will cost you about
$27,000.) This water is used in nuclear reactors not
because of it's heat transfer properties, but because
of it's neutron interaction cross-section.
If you are still interested in obtaining some heavy
water, you would have to talk to AECL (Atomic Energy
of Canada Limited) directly. The heavy water we are
using is on loan from them. There are no laws against
using heavy water, just possibly bureaucratic barriers
in obtaining it.
- Phil H
Don't let the $27000 dollars scare you off, after all thats only Canadian dollars
2) Is it expensive?
Hi,
in obtaining it.
- Phil H
