Somebody Please Help Me!!!!!!!
[~LeNnY~]
Melbourne, Australia
I turned on my comp this morning and it won't go....!
it was running fine last night and now i get some message saying:
"Windows could not start because the following file is missing or corrupt:
\windows\system32\config\system"
then it ay you can attempt to repair, by starting windows setup using original setup cd-rom... i'm just not sure how to do that... :(
i am using winxp pro....
heeeeeeeeeeeelpppppppp!!!!!!!!!
-lenny
XprincoX
bargain hunter
Irvine, CA
well basically boot using the winXP install cd or go to the setup, and when ur prompted to select the install type push R, i believe for repair, then it'll just reinstall the needed files... :burn:
takiwa
are you overclocked? that is the best sign on an o/c'ed rig that you are either a) not stable, or b) you have data corruption due to a failing part (like the HDD, or RAM)...
if you are o/c'ed, you need to clock back down before repairing...
